Archicad 14/13 install problem - JVM not found
I tried to install the AC14. During the installation comes to 1% then, goes to a box and a message pops up shortcuts that the installation was successful. Unfortunately, nothing is installed. In the installation folder is only a log.txt file:
(2011-03-24 20:14:20), Install, com.installshield.product.service.product.PureJavaProductServiceImpl$Installer, err, ProductException: (error code = 601; message="JVM not found")
STACK_TRACE: 8
at com.installshield.product.actions.JVMResolution.install(JVMResolution.java:171)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.checkUninstallerJVMResolution(PureJavaProductServiceImpl.java:4793)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.install(PureJavaProductServiceImpl.java:4554)
at com.installshield.product.service.product.PureJavaProductServiceImpl$Installer.execute(PureJavaProductServiceImpl.java:3758)
at com.installshield.wizard.service.AsynchronousOperation.run(AsynchronousOperation.java:41)
at java.lang.Thread.run(Unknown Source)
What to do?
I got the idea of ​​installing AC 13. Same problem.
I tried several versions of Java from the newest to the older ones. did not help
Any idea?
My system:
Core 2 Duo E4300
3GB
9800GT
WinXP sp3
5 Replies 5
getting this sounds simular
(Jun 8, 2011 10:47:31 PM), Install, com.installshield.product.service.product.PureJavaProductServiceImpl$Installer, err, ProductException: (error code = 601; message="JVM not found")
STACK_TRACE: 8
found if i removed microsoft visual the install worked
i read a lot posts and i tried a lot things but the problem is same. When progress bar goes to 1% the installation finished with success!!!! In the destination path (by default Program files/graphisoft/archicad 15) there is only one log file. The problem is the same in all cases:
The trick is very simple. Just install java in /Program files/java/jre1.6/
The default installation path of java is /program files/java/jre6/
simply uninstall java 7 or any other latest java you have using control panel-uninstall program. run archicad 15 or 14 installation and Archicad will install its compatible version of java. you can afterwards reinstall your java version
Thx...you just save my day
