Archicad 18 and codemeter problems with IPV6
Hello everyone,
I past my morning with tech support at boston. Excellent service. We did try to find out wy archicad 18 upgrade 5100 don't want to start. It seems that code meter have a problems with IPV6.
Executing Broadcast for CodeMeter License Servers
2015-04-08 13:52:07: Entry (101074:63:134478911) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6) with StationShare Mode
2015-04-08 13:52:07: API Error 200 (ENTRY NOT FOUND) occurred!
Do anyone have this problem
Martin
Québec city
3 Replies 3
Hello Martin,
I think I have the same problem. I got the following error message in the CodeMeter Control Center:
2015-05-20 11:04:20: Entry (xxx) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(INTERN\e_kallai) with StationShare Mode
2015-05-20 11:04:20: API Error 200 (ENTRY NOT FOUND) occurred!
Do you know how to solve this problem maybe?
Katalin Borszeki
Hi All, we have contacted Wibu support with regards to this issue!
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Katalin Borszeki
Hi All, please see the answer from wibu support below:
"CodeMeter does indeed support IPv6. The error only means, that they don’t have this entry on any of their CmContainer.
This can happen for example when your customer tries to use a module of your application, which requires an additional license, which the customer does not own.
In a CmDust.log you could see, that the customer does not have this license entry. (101074:63:134478911)
To generate a CmDust.log file, please follow the steps below:
1. Plug in your CmDongle
2. Start CmDust via “Start -> All Programs -> CodeMeter -> Tools -> CmDust”
3. A command prompt window will be opened automatically and also will be closed automatically after a few seconds
4. Now you will find the file "CmDust-Result.log" in your user directory which opens automatically in a new explorer window. If you like, you can open this file with a usual text editor (e.g. notepad) to see contents of the collected data"
If further questions remain, let us know! Best
Katalin Borszeki
GRAPHISOFT
