Archicad 19 installation cannot be started
My Archicad 19 installation gives me the following error message:
Installation cannot be started. Please check the installation files.
I've tried to disable AVG antivirus and reinstalled java but that did not solve the problem.
Does anyone know a fix for this problem?
I'm running windows 10 on a Lenovo Y510P laptop
16GB ram
Core i7 4700MQ
NVIDIA GeForce GT 775M SLI
4 Replies 4
Sometimes there is a download error. You can try downloading the file again and see if that works.
Also make sure you have administrator rights when installing ARCHICAD.
Jeff Kogut
I've been running Java 8 update 40 in order to maintain backward compatibility with detail markers originally placed in .pln files started in 17 or earlier.
I installed the update and I thought I was in the same boat as Mskov with the latest 5005 update. But the ArchiCAD splash screen came up after about 5 minutes. And then the clue - a Java prompt. I installed the latest Java and rebooted. Now it works as normal.
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
Hello. New here.
I just got my archicad 19 licence and I have the exact same error. Does someone have a solution for this?
I have tried:
Redownloading
Updating java(also using a older version of java, JRE 8 build 45)
Disabling firewall/antivirus
"Run as administrator"
Windows is updated to the latest.
Extra info:
Fresh windows 10 install
PC is a HP zbook 17 G2
Any ideas?
It could also be that some software pre-installed with Windows by the hardware vendor is blocking access to some folders the ARCHICAD installation wants to access. In your case you should look at programs installed by HP.
