Archicad 21 is freezing when using the railing tool and 3D view stops working
So again, im working on this big project and ive ut my railing in and changed the outlines of the railing to background When i did that all my project just freezes and im not able to do anything unless i delete the railing And help?
1 Reply 1
Lingwisyer
Guru
Does this happen if you use a default railing? Might you have some part of your railing going off into space, or be corrupted?
Ling.
