‎2020-08-19 03:01 PM
‎2020-08-19 05:55 PM
‎2020-08-27 03:55 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-09-03 10:33 AM
vistasp wrote:
Does this still happen if you remove those files from the recent projects list?
‎2020-09-03 10:39 AM
mnguyen wrote:
Hi Johann,
Thank you for sharing the issue and I am sorry about the experience!
From my experience, at startup, Archicad will check the information of the files listed under Recent Projects, to make sure that at least they are there. This verification seems to make Dropbox think that the file is needed, which triggers the synchronization that you have here.
I suggest contacting Dropbox about this in order to find out how their algorithm work. Unfortunately, we do not have any information about this Smart Sync from Dropbox.
Thank you for your understanding! If you have any further questions, feel free to let me know!
Best regards,
Minh
P/s: although this may not be relevant to the issue here, I would suggest avoiding saving Archicad files directly to folders synchronized with the cloud, as it could lead to data loss
‎2020-09-03 11:51 AM
joimagg wrote:Hi Johann,
Hey, I doubt Dropbox can change is from their end, smart sync downloads files even when just previewing the files in Explorer's preview plane. Thats ok since thats often what I want it to do.
But this bulk check Archicad makes for older recent files is very heavy and time consuming.
I must add that the Dropbox Smart Sync function is very important now that many of us are working from home. I don't use it at the office but at home on a small laptop it is vital.
The recent files preview in previous Archicad versions doesnt cause this dropbox problem so there's something that has been changed in AC23. Being able to deactivate recent projects would be nice.
Hope you can look into it from your end.
Minh Nguyen
GRAPHISOFT
‎2020-09-08 02:22 PM
Minh Nguyen
GRAPHISOFT
‎2020-09-10 01:39 PM
mnguyen wrote:
I had some explanation from the developer: the Startup application indeed makes a quick read for some information from the files contained in the recent file list. Maybe that's what triggers the synchronization in Dropbox. Unfortunately, we are unable to disable saving recent files to this list. The only workaround I can suggest in this case is to delete the "Recent Documents (Symbol).prf" and "Recent Documents (Project).prf". Depends on the OS, it can be found inC:\Users\<user>\AppData\Roaming\GRAPHISOFT\ARCHICAD xxxxor Users/<user>/Library/Preferences/GRAPHISOFT/AC xxxx. This will wipe out the list in the startup dialog.
I am very sorry for the inconvenience, but unfortunately, using a cloud folder to store plan files and other objects which is synchronized in Dropbox or other cloud services is not a supported workflow. If you have any further questions, feel free to ask me again!
Best regards,
Minh
‎2020-09-10 01:43 PM
Minh Nguyen
GRAPHISOFT
