2020-08-24 04:20 AM
2020-08-24 04:59 AM
2020-08-24 10:32 AM
2020-08-24 03:12 PM
2020-08-25 03:52 AM
2020-08-25 09:00 AM
2020-08-31 11:21 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-31 11:59 AM
2020-08-31 12:32 PM
DGSketcher wrote:Hello,
Hi Minh, I am on an 3.6GHz i9 8 core with 16Gb Ram and 512Gb SSD working on a 110Mb .PLN file and the save process not only for the PLN file but also each MOD file is painfully slow and a lot longer than I would have expected. Activity Monitor frequently shows Archicad as Not responding. I am using about 12Gb of my 16Gb ram. As I mentioned above on first install AC24 was flying on Save now it seems to crawl following the last Mac update.
I have just opened the file and the attached shows the memory report for Archicad, what troubles me about this is it is reporting 3 hangs already!? Having done no work and resaved the file it has now increased to 6 hangs and the virtual memory has jumped!!! Surely this isn't normal?
Minh Nguyen
GRAPHISOFT
2020-08-31 01:18 PM
