2021-09-02 01:35 PM
I'm a student, and using Archicad 24 from last year. Currently I'm working on a new project, but would like to switch to 25th version. If I delete 24 and install 25, will I be able to open my work project?
Solved! Go to Solution.
2021-09-02 01:51 PM - edited 2021-09-02 01:51 PM
Hey luchisty! In short the answer is yes, you can open projects done in older versions while using AC 25. You can also check out this article for more information Migrating to Archicad 25 (graphisoft.com)
2021-09-02 01:51 PM
Yes. On first open 25 will migrate the project. Also you can have both AC24 and AC25 installed in your system without issues.
2021-09-03 11:10 AM - edited 2021-09-03 11:11 AM
@luchisty If you can, then you should keep AC24 in case you encounter a bug in AC25 that you can't work round and have to save back to AC24. I had this just yesterday with a legacy project I tried to use in AC25.
