Installation & update
Archicad 25 4013 File Open / Save dialog boxes huge on macOS Monterey
psalva
Help please,
I can´t resize Open / Save dialog box on macOS Monterey.
Archicad 25 4013
Thank you.
2 ACCEPTED SOLUTIONS
insideru
It's a known bug. Check the following tutorial on how to fix it.
https://www.learnvirtual.com/how-to-resize-long-open-save-dialog-boxes-in-Archicad-on-mac-monterey/
ARCHICAD 28 INT
macOS Sequoia
I was not. I updated it to 5010, which has fixed the issue. Thank You
13 REPLIES 13
insideru
ARCHICAD 28 INT
macOS Sequoia
Thank you! 👌
That's great! Anyone know what the command is to fix it for AC24?
insideru
Dunno, but you can try to replace 25 with 24:
defaults delete com.graphisoft.archicad24 NSNavPanelExpandedSizeForSaveMode
defaults delete com.graphisoft.archicad24 NSNavPanelExpandedSizeForOpenMode
ARCHICAD 28 INT
macOS Sequoia
Yes, that doesn't work. If I find the soltution I will post it.
KRUChY
you can use my Shortcut for Archicad 23 - and edit it, just by changing 23 to 24 or 25.
It works lightning fast and it became no more annoying
Archicad reset size windows
insideru
The preview build 7000 states that bug as fixed. Don't update if you are working with others in teamwork tho, projects opened with b7000 won't be usable on previous builds.
ARCHICAD 28 INT
macOS Sequoia
Awesome - much appreciated!
Thanks Kruchy!
