‎2021-12-03 05:45 PM
Help please,
I can´t resize Open / Save dialog box on macOS Monterey.
Archicad 25 4013
Thank you.
Solved! Go to Solution.
‎2021-12-03 05:55 PM
It's a known bug. Check the following tutorial on how to fix it.
https://www.learnvirtual.com/how-to-resize-long-open-save-dialog-boxes-in-Archicad-on-mac-monterey/
‎2022-06-20 09:05 PM
I was not. I updated it to 5010, which has fixed the issue. Thank You
‎2021-12-03 06:30 PM
Thank you! 👌
‎2022-02-17 08:43 PM
That's great! Anyone know what the command is to fix it for AC24?
‎2022-02-17 09:16 PM
Dunno, but you can try to replace 25 with 24:
defaults delete com.graphisoft.archicad24 NSNavPanelExpandedSizeForSaveMode
defaults delete com.graphisoft.archicad24 NSNavPanelExpandedSizeForOpenMode
‎2022-02-17 09:24 PM
Yes, that doesn't work. If I find the soltution I will post it.
‎2022-02-17 09:25 PM
you can use my Shortcut for Archicad 23 - and edit it, just by changing 23 to 24 or 25.
It works lightning fast and it became no more annoying
‎2022-02-17 09:28 PM
The preview build 7000 states that bug as fixed. Don't update if you are working with others in teamwork tho, projects opened with b7000 won't be usable on previous builds.
‎2022-02-17 09:33 PM
Awesome - much appreciated!
‎2022-02-17 09:34 PM
Thanks Kruchy!
