2023-11-17 02:42 PM
Just a heads up, we have upgraded all of our office machines to the Update 4 of Archicad 26 and so far none of the ARM/ Silicon based machines will launch Archicad 26. I have reported to local support.
Solved! Go to Solution.
2023-12-04 08:16 AM
Dear @jimmyp,
I am sorry to read that you had hard time in the final rush of your documentation. I hope that the suggestion of @Lee Hankins helped, and a bit of more waiting solved the issue for good. If not, the local support team will be happy to assist you: https://graphisoft.com/contact-us#contact-us
Tamás Gáspár
Manager, Partner Technical Support, Graphisoft
2023-12-04 04:00 PM
Thank you for responding. I was able to manually delete those files, once I found them, and now it seems to work fine. Regards, Jim
