2023-11-14 04:07 AM
My AC is crashing pretty much every time I edit any text (labels, text boxes) in elevation. Its also having a lot of trouble with a very simple model thats made into a 3D view and placed on a layout. The issues seem buggy, as I've had AC for over 15 years. My OS and AC are all updated with the latest. I'm hoping that I can figure this out tonight so that when I get back to work tomorrow I can sort this out before my work day starts. Any help would be massively appreciated!
Solved! Go to Solution.
2023-11-22 04:04 AM
I'm still on Ventura (13.6.2) and don't see the issue in 27.1 on an ARM Mac ... so it must be a Sonoma thing as you're assuming, or possibly something with the Intel version...
Just a wild stab ... did you try going to your Work Environment > User Preference Schemes > Advanced Redraw Options and turning off the slider for 2D Drawing Acceleration?
2023-11-22 10:35 AM - edited 2023-11-22 10:36 AM
Hi All,
crash occurs on MacOS 14 when CAPS is on and user is deleting text. This is a MacOS Sonoma bug, that we are aware and we are providing a workaround in AC26 Update 5 and AC27.2.0.
If you wish to fix this on your own then a possible workaround is also available for this, by turning off the caps lock indicator introduced with MacOS 14.
Disable macOS Sonoma Text Insertion Point (Cursor) / Caps-lock Indicator
Disable Caps Lock Indicator on macOS Sono… - Apple Community
Please note that this plist edit is system wide, so not only for Archicad.
Best regards,
Daniel Kassai
Product Management
2023-11-22 05:46 PM
This seams to work!!!. thank you
2023-12-13 08:30 PM
I am having similar issues after updating to Sonoma 😞
2023-12-13 10:29 PM
There's a new update that I just download today. Hopefully this will fix the issue.
2024-02-06 12:36 PM
Same here !! We are also using Archicad for last 15-17 years. Recently moved to ArchiCAD 27 from 20...
2024-04-17 12:13 PM
Hello
I still have this problema at work in the Windows 10 version (with the latest version of archicad update).
Please help!
2024-04-18 03:18 AM
As far as I know, this is a MAC only issue.
Are you sure it is the same problem?
Have you reported it to your local support?
2024-04-18 03:18 PM
Barry,
This is only a MAC & Archicad issue, correct? In my case editing text while having caps on does not always crash my machine. Do you know if there's a fix for this yet?
2024-04-19 04:50 AM - edited 2024-04-19 04:51 AM
As far as I know it is a MAC only issue.
I think it is editing text with CAPS lock on and using backspace or delete as well?
But I believe it has been fixed in the latest update.
27 build 5003
26 build 7004
