2023-11-07
03:30 AM
2023-11-13
09:08 AM
Aruzhan Ilaikova
I usually set my units to Fractional Inches. When I try to move an element a fraction of an inch using the forward slash (i.e. 3/4) the input gets an undesired entry upon hitting the forward slash ("/"). This didn't happen in AC26. The glitch also happens on both Windows and macOS. To get the screenshot to show 3/4, I had to type /4 and then move cursor back to front and type the 3. It works and moves it 3/4", but I hate that solution. I can also use decimal (i.e. .75) but that isn't user friendly when inputting other fractions in decimal format. I hope this is an easy fix.
Solved! Go to Solution.
2023-11-10 01:18 PM
Unofficially been told that it is in the "to be fixed" list but it has been there in different form since the Beta.
another Moderator
2023-11-07 01:38 PM - edited 2024-01-30 11:07 PM
Can Confirm that if Units are set to Fractional Inches it typing / removes the first digit working as if Decimal Inches is selected.
This is a Bug in 27 introduced when they added math functions to the tracker.
The other bug is this one:
Initially during the Beta "/" after a digit was used for division, this was changed to "//" so that tipping "#/" would mean inches.
Except that it was not a complete fix, since it only works in some occasions and your use of fractions only might be showing more errors.
It took me a while to figure out what is wrong in 27 but basically the standard workflow for placing or starting to draw a specific distance (in inches) from a reference point has been:
In 27 this works as long as you are moving in the negative direction (down or to the left).
IE if you want to place an object 36" to the left of the reference checkmark you type:
This one still works.
If you want to place it to the right by typing
it will ignore the / and start 36 feet from the reference point.
I wish there was an option to globally deactivate that "upgrade" and have the tracker work as it has for the last 20+ versions.
This is another of the examples of a well intention upgrade done by someone that has no idea how AC is used beyond their little corner of the desk. If you use the metric system there are no issues but sadly that is not the only unit system in the world and the developer in charge forgot that the US does not work like that.
another Moderator
2023-11-09 06:02 PM
If it is a bug, are they going to fix it? I rely heavily on moving things a fraction of an inch when designing, and this not working as it has in the 20+ versions really hurts productivity.
2023-11-10 01:18 PM
another Moderator
2024-01-30 10:29 PM
Just spent 15 minutes trying to figure out why 2/ wasn't working to divide a distance in half. FINALLY stumbled on your post that explains the // for division. You would think GS would change ANY of their marketing materials for the intelligent tracker to reflect that...
2024-02-08 10:40 PM
This is still broken in 27.2.0 Preview. ☹️
another Moderator
2024-02-09 05:02 AM
Maybe it's finally time for everyone to transition from the freedom unit!
2024-02-09 05:07 AM
I agree!
2024-02-09 12:28 PM
Would love to but we are stuck with it…
another Moderator
2024-02-11 02:59 PM
Sorry for my ignorance, but what is a "freedom unit"?
