Installation & update
SOLVED!
Archicad 27 - Tracker Input glitch using forward slash while in Fractional Inch input
tpike66
I usually set my units to Fractional Inches. When I try to move an element a fraction of an inch using the forward slash (i.e. 3/4) the input gets an undesired entry upon hitting the forward slash ("/"). This didn't happen in AC26. The glitch also happens on both Windows and macOS. To get the screenshot to show 3/4, I had to type /4 and then move cursor back to front and type the 3. It works and moves it 3/4", but I hate that solution. I can also use decimal (i.e. .75) but that isn't user friendly when inputting other fractions in decimal format. I hope this is an easy fix.
AC28 USA • Alienware X15 R1 Laptop • 11th Gen Intel Core i7-11800h @ 2.30GHz | 32 GB RAM• Windows 11 Home | 64-bit • Nvidia GeForce RTX 3070 Laptop GPU | 24 GB • LG 35wn65c-b monitor
17 REPLIES 17
IIRC,  "Freedom unit" makes reference to "Freedom Fries" which was the name one of the USA parties wanted to use for "French Fries" because the french were against the war in Irak…
So USA units vs Metric
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Wow, I didn't know that, thanks for the info.
itadmin
I have always use the slash for fractional inches as 1/8/ for 1/8". Does this not work anymore because of the "improvements" made described in this post? Tried using this recently and what I was typing reverts back to the original dimension. Not sure I was even aware of this "upgrade" until now.
Eduardo Rolon
Yes. Now it only works on specific items. Still not fixed.
AC29 US/INT -> AC08
another Moderator
tpike66
This seems to have been fixed in AC28, if not in AC27.
Eduardo Rolon
Still not fixed in 28
AC29 US/INT -> AC08
another Moderator
It's working on my installation of Windows 11 with AC28. I think it also worked on my installation of AC27 in a later update too.
Maybe not fixed on the Mac version?
Nope, the bug still exists.
In some cases it works but the particular case that I wrote above which is the way I have used AC since V8 is still broken.
AC29 US/INT -> AC08
another Moderator
