‎2025-01-10 06:25 AM - edited ‎2025-01-13 01:41 AM
We are deploying Archicad v28 via SCCM/MECM. The installation works just fine when there's a user logged on, but when it is pushed to machines while no one is logged on, the installation gets stuck on this part (see attached logs). This behavior was not present on v27. Anyone here who experienced the same?
Operating system used: Windows 10 22H2
Solved! Go to Solution.
‎2025-02-19 06:33 AM - edited ‎2025-02-19 07:42 AM
Hey there, we have the same problem, did you ever find a workaround?
Thankyou in advance
EDIT: Setting the deployment type to run as a 32bit process in SCCM worked around it for us.
Thankyou in advance
‎2025-02-26 07:42 AM
Hi, that was a quick fix. Thanks!
