3 weeks ago
Hey, i am workin on my project and have deadline in a couple of days. Yesterday when i closed my project i run instalation of last windows 11 update: Today morning i wanted to contiue in my project but it crashes immediately after open archicad project. I can open archicad 28 without opening any project but if i start a new one or open any old project it crashes and bug report. I tried to uninstal the windows update but it didnt help. Do you have any idea what can i try? I was thinking about reinstal archicad 28 but in my project i used some imported library object and i am afraid of loosing them after reinstalation.
Operating system used: Windows 11 24H2
3 weeks ago
If rolling back the Windows update did not work (assuming you have restarted your machine) then send off the bug report.
Take note of the bug number and follow up with your local Archicad support (remembering it is holiday season).
If you re-install Archicad, you will not lose the imported library objects if they are in the Embedded Library of the project.
If they are in a separate folder that you load as a linked library, that will be fine as well, so long as you do not delete that folder.
3 weeks ago
At te fisrt thank you for reply. As a student I am using student version of archicad and for czech republic i didnt find any Archicad support :(. But yes i did restart my notebook. The objects are not form archicad librar, I download BIM object as LCF file and after import to archicad. Sorry but how can i reinstall Archicad with keeping the library file if it is even possible.
3 weeks ago
If you get Archicad working again and you reopen the file, if the objects were added to the embedded library, then they will be ready for use and there is nothing you need to do, as they are embedded in the file.
If the objects become "Missing" in the library manager, then all you need to do is re-link the libraries that you have downloaded.
