DanCoyle
Archicad 29 on Apple MacBook Neo - will it work?
Hi I'm thinking of getting a new MacBook Neo for remote working / on the road working. I currently use an 8 year old iPad Pro for this purpose (BIMx, Email, Word, Excel, Internet browsing, Dropbox etc.) and it has served me perfectly well - but needs an upgrade. I was wondering would MacBook Neo be an option that would also allow occasional ArchiCAD usage when I am away from the office (my office machine is a Mac mini, M2 chip 8 cores, 16GB Memory, 500GB SSD - and this machine works just fine with AC29 & TwinMotion). Has anyone tried installing AC on the MacBook Neo? Are the specs sufficient? (A18 Pro Chip, 6 core CPU, 5 Core GPU, 8GB RAM, up to 512GB SSD). I do mainly residential projects  - max model size 500MB (most much smaller). Thanks for any advice.
Dan Coyle, Dublin, Ireland    www.danielcoylearchitects.ie
ArchiCAD 26 Solo (user since v.15, 2011)
iMac 27" Intel i7 (2020) 64GB RAM, 1TB SSD, 16GB Radeon Pro 5700 GPU
Mac Mini M2 (2023) 24GB RAM, 512 GB SSD, 10-Core GPU
8 Replies 8
I would be surprised if it was adequate for any serious work.  While most would gravitate towards a MacBook Pro for "real" work, it is conceivable that an M5 Air would be a compromise for occasional residential work.
Will be interested to hear if anyone has actually tried AC on a Neo.  Would love to be wrong. 🙂
fortythree
hi... finally something I can shed some light on. I borrowed a Mac Neo today, purely out of curiosity as I was interested to see if this could be used as backup computer, or for temp helpers etc...
The answer is ... it can, to an extent. The Neo is actually fine handling a complex 29 model if you're just working on the laptop. I saw severe restrictions as soon as I hooked it up to an external screen. It just wouldn't offer a native resolution, so everything was slightly pixelated. (Studio Display 27, I usually run that at 3200x1800. the neo only offered 1920x1080/2560x1440 or 3840x2160. All options looked slightly off but not so bad that you couldn't work with it for a few hours.
Working itself in the AC model was actually totally fine. no delays, beach balls or any kind of errors.
At the end I decided to let it run a little rendering that I had previously used on my other machines. (not that we do that much anymore in the days of AI).
Anyway, on my M5Pro that image takes 4min31, on an older M2Pro the same image takes about 10minutes. On the Neo I killed it after 10 and it had done about 15% of the final pass.
In summary... It's not suitable as a proper daily workhorse (with a big screen), but... if you're travelling or just need to work on the laptop itself (I used an iPad as an external screen and that was perfectly fine) then it actually is an incredible bargain. especially as it runs on the latest OS...
fortythree
Lee Hankins
This is really helpful, I have been looking at getting a macBook Neo as a company pool laptop. I don't suppose you know if it can run Archicad and share the screen via Teams?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
ryejuan
Have you considered macbook air?
WINDOWS 11 PRO
Lee Hankins
Just as an update, we now have a MacBook Neo and have installed both 29 and 30 on it. 29 opens and seems to work fine, 30 will not open, it launches, allows GSID log in and crashes when any file is attempted to be opened.
Lee Hankins
macOS Tahoe (26.0)
Karel Landa
Probably a macOS27 bug where if you click "New" button from homescreen, AC crashes?
Have you tried opening a file from Finder?
From Archicad 17
MacBook Pro M1 Max
Lee Hankins
Hi, the Neo is still running of macOS 26 Tahoe. We have tried opening a file from Finder as well as the start screen.
Lee Hankins
macOS Tahoe (26.0)
