Installation & update
Archicad Crashing at Startup
isavyy
From one day to the next, I'm getting this error from Apple immediately upon opening AC28.
Any ideas what could be causing this?
Operating system used: Mac Intel-based 14 Sonoma
Lingwisyer
Guru
Well, it says it was terminated due to Namespace DYLD, Code 1 Library missing.... Have you tried reinstalling? Office apps apparently use that, do those work for you? Are you on the latest build of Sonoma? There was an update this month.
Lingwisyer
Guru
isavyy
It worked after re-installing. Thank you for your help!
Setup info provided by author
