Archicad hotfixes
Hello everybody.
Does anyone know where can I download previous hotfixes for Archicad (for example ac10-1183)? As going through "check for updates" command in Archicad, I have only the option to download the latest hotfix.
Thank you.
6 Replies 6
Laura Yanoviak
Go to GS Technical Support (also available from the Help Menu).
Edit: The link I provided is the US Tech Support -- I can only assume that your Help Menu will take you to your area's page.
Thank you so much Laura, but I can't seem to find Technical Support in Help Menu "Check for Updates" is the best thing I can do, but as I said this gives me the possibility to download only the latest hotfix.
Laura Yanoviak
Maybe someone with the INT version can point you to the correct link???
That's what I'm hoping for.
Thank you anyway.
Adi Tudoreanu
PatriciaLe_o
I guess the INT version doesn't have this option...
That's how my help looks like:[/img]
Patricia Leão
AC21 INT Full
MacOSHighSierra
Laura Yanoviak
That's unfortunate. I would hope your local reseller could guide you to such a site (if one exists).
