Architerra road fill
Tom Krowka
Farizio:
Glad you are working today. Another question...
Is there a setting for the fill of the road in 2d, like the color terrain tool? That is a very handy feature.
I tried the settings in the object tools once I selected the road, but nothing seems to work there. (Except for the sidewalks). I would think there would be a setting for that in the Achiterra road tool.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
Fabrizio Diodati
Hi Tom,
in the attached image a description about what you can get.
In the Road User Interface section you can set the color of the 2D fill of the road (default color is white).
BTW, very important (!), check you ArchiCAD display settings: you should use/visualize the fills (they shouldn't be set as transparent!).
Friendly
Fabrizio
Fabrizio Diodati
Fritz T
Hi, I'm experiencing a problem creating a coloured area on the site model that I have created using Architerra. I follow the instructions, select the outline of the fill, and the model, but the command does not seem to execute. Other tools, such as the roads, the platforms and buildings tool do work, when following the same process.
What can I be doing wrong?
AC 6, through 27
iMac 27' 3,1 GHz 6-Core Intel Core i5
500GB OS X12.7.3 Monterey
