KileyBode
Black Screen Appear When Installing NVIDIA Graphics Driver
Greetings, I have a NVIDIA graphics driver, but recently I am encountering a problem while installing this on my PC. When I am installing this the black screen appears. I have no idea what could be the issue. Does anyone have any idea about how can I able to fix it?
4 Replies 4
Lingwisyer
Guru
1. IS this related in any way to AC?
2. Either way, you need to provide more detail.
2a. Are you installing the GPU or AC?
2b. What is going black
2c. When is it going black
KileyBode
Actually the black screen is appearing when I am trying to install the GPU. But after searching the issue on Google, I came across this guide. The main issue was in the GPU driver. The GPU driver was defective. Anyway after getting the article, I followed some methods from there. First I run Windows black screen troubleshooter and devices troubleshooter. Then updated the BIOS and finally verified the graphics driver whether it was signed.
After doing the methods perfectly, I was trying to install the GPU and I had no longer any issue while Installing it.
Lingwisyer
Guru
Good to know your resolution. Do note though, that this is an ArchiCAD user forum, not a computer hardware or tech forum.
Eric Milberger
True but you cannot have one without the other - so both will always be a shared discussion.
Eric Milberger, Architect | Master Planner
