Black overlay on -1 Fills in Layout View
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-09-18 04:11 PM
2008-09-18
04:11 PM
Please see example attached.
Labels:
- Labels:
Performance
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-18 11:16 PM
2008-09-18
11:16 PM
Have you checked the pen set assigned to the drawings? That's where I'd start.
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-19 03:29 PM
2008-09-19
03:29 PM
I have checked the pen set, but the empty fill pen doesn't appear to exist in the pen set. Another confusing thing that would seem to suggest it isn't a problem with the pen, is that it doesn't print this way. It only displays the black overlay on the screen.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-09-19 04:18 PM
2008-09-19
04:18 PM
We did some experimentation this morning and discovered that the problem was not only limited to that particular file, it was also limited to his particular teammate name as he could sign in under my name and the black overlays were gone.
So, while we were not able to identify and solve the specific problem, we created a new teammate name for him and will later delete his old name (and with it whatever saved settings were causing the malfunction) under administrator privileges.
Thanks,
Thanks,
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-10-29 07:17 AM
2008-10-29
07:17 AM
does this person have their plan view background color set to black? Or did they ever even briefly have it set to black and change it to white?
Check the Grids and Backgrounds dialog in the plan view. And then check it again while in the layout view. If the while in the layout view the grid background shows black, then this is part of the problem. I had a similar problem with a template file that had a yellow background. i changed it to white but when I go to my layouts, all items that use the -1 recognize the background as being yellow. In your case, I would guess it is recognizing black. It could be that an AutoCAD drawing was open and the user elected to change the archicad background to match the typical black autocad background and may have stuck the work environment.
Unfortunately, I have no solution yet. In fact, that is why I am here looking for one myself.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-10-29 09:51 PM
2008-10-29
09:51 PM
Daniel, are you on 11 or 12?
Could you please add that to your signature?
Thanks from everyone.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-10-29 09:55 PM
2008-10-29
09:55 PM
Updated.
New hotfix will be installed this week. I don't know yet if there might have been a fix for this issue.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-06 11:13 PM
2008-11-06
11:13 PM
i've got the same problem, only this is not a teamwork file. so i can't just create a new profile. This also happened mid-project. it was fine at one point, but then I opened it recently all the -1 fills have a dark grey look in the layout book. also to note they don't print just like the previous guy... any luck with this? i'm using v.11 and i'm on the current build for v.11.
