CPU or GPU for rendering?
hello,
i'm in the search for new notebook up to price 700 eur, and i have a dilemma which one to buy.
so, I have few questions:
1st: is it more important to have more cpu cores or better gpu for faster rendering in archicad, artlantis, lumion etc.
2nd: some i7 cpu comes with only 2cores and others with 4 cores. is there significant difference?
3rd: how important is number of threads, because i saw AMD cpus with 4 cores and 4 threads, unlike the i7 which has 4 cores and 8 threads
Thank You very much!
14 REPLIES 14
1. As far as I know CPU is what is being used by most current rendering applications. Some applications start to appear that use the GPU or GPUs but there is only OctaneRender currently (that I know about) that is using GPUs:
http://archicad-talk.graphisoft.com/viewtopic.php?t=41417
So for ArchiCAD, Artlantis etc. CPU is more important.
2. A 4-core processor is better than a 2-core processor as it can handle 4 processing threads instead of 2.
3. Number of threads is what really counts. Intel has Hyperthreading which means that 1 physical core can run two processing threads in it. A 4-core 8-thread processor is better than a 4-core 4-thread processor. From the application's standpoint the former can process 8 threads for ArchiCAD or the rendering application, while the latter can process only 4 threads.
Even in Graphisoft's pages they say they recommend as many cores as possible:
http://www.graphisoft.hu/support/system_requirements/
Note: Processors with 4-8+ cores are recommended to fully exploit ArchiCAD 17's performance capabilities.
In the last several releases Graphisoft has made great efforts to fully utilize multi-core processors and get as much performance out of them as possible. This is especially true with AC17 where they specifically say 4-8+ cores is really recommended. Previous they only said you should use multi-core processors, which means at least 2 cores.
and what about now. Can ArtLantis 6 use GPU graphics card?
Nuge
Try Octane for archicad
http://home.otoy.com/render/octane-render/
Nuge
AC27 i9 11900K / 128G ram / GTX 3090 / D5 Render
I want to know if Artlantis 6 can use GPU processing. That was not clear from what I was able to find on their website.
I don't think I need Octane. I have Maxwell Studio/Render 3.1,an older version of Artlantis Render, and of course CineRender in ArchiCAD.
I don't think Artlantis 6 uses GPU for rendering.
http://artlantis.com/en/features
If it did they would be widely publicizing it as it would be much much faster than CPU-based rendering:
http://www.gpurendering.com/technology/gpuVsCpuRendering.html
https://www.youtube.com/watch?v=6VHzONYfgUg
http://blenderartists.org/forum/showthread.php?346401-Maxwell-Render-on-GPU-(CUDA)
I was wondering if there was a way to utilize my GPU for 3D view?
I have fiddled around with the Nvidia control panel and all that. But still, Archicad uses 0% of my GPU
I have a GeForce 870m and it has openGL 4.5 ( thats why I baught it. I thought it would help.)
AFAIK, only BIMx uses the GPU. ArchiCAD itself does not:
http://helpcenter.graphisoft.com/technotes/setup/hardware-compatibility/recommended-hardware-for-gra...
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
