2022-05-22 06:32 PM
Good afternoon,
I wonder if the Archicad 25 in terms of rendering with MAXON uses the CPU or GPU?
I can't configure for GPU and rendering is done by the CPU.
Is this setting possible?
2022-05-22 06:36 PM
Pretty sure maxon is all cpu, programs like twinmotion utilize the gpu
2022-05-23 11:34 AM
So it's not even possible to configure Archicad 25 to work via GPU?
By the way, does Archicad 25 work with single core or multicore?
2022-05-24 04:30 AM
I believe the Redshift renderer uses the GPU, but that requires you being on an active SSA...
If you have hardware acceleration active, which I think is the default, your 3D window should be rendered via the GPU.
Regarding multicore workloads: https://community.Graphisoft.com/t5/Setup-License-articles/Multiprocessing-and-Archicad/ta-p/303631
Ling.
2022-05-24 08:58 AM
maxon render modes:
#1 standard, only CPU
#2 redshift, only GPU
