2020-07-21 03:30 AM
2022-09-28 11:01 PM
Hi There!!!.
I just installed AC 26 in a computer I7 with 32GB ram Dell Precision 3510 (the computer is a little bit old however still working perfectly with High-End software and producing renderings in Cinema 4d)
Since I installed AC26, I had to install my Dell Power Management and select the option Cool, which reduced the performance of the computer because I started to have the same issue as you. my computer was Crashing because of Temperature issues, and I know this computer is perfectly fine because of the rendering software, and also I use music software production on it which demand a lot of Performance power and the computer doesn't crash.
2022-09-29 03:09 AM
Looks like the original post Ling answered has been removed as it may have been a spam post.
However ...
Your rendering software may use the GPU to calculate the renders, so won't be stressing the CPU as much.
Archicad uses the CPU for renders - unless you are using the Redshift engine.
So the CPU will be running flat out, possibly causing the overheating.
I have no experience with music software, but maybe that is not taxing the CPU as much as a render would - or maybe it also uses the GPU?
2022-09-29 03:19 AM
My music software tax the CPU like crazy and the computer doesn't crash, also I have other heavy CPU software and it's taxing the computer even higher than AC26 and the temperature of the CPU is 75-80 and doesn't crash I've been monitoring AC26 and as soon as the temp reach 75 Its shutting down the computer
2022-09-29 03:26 AM
So Archicad is not crashing with the bug reporter?
The machine is just shutting down with no warning?
Have you tried adjusting the 2D Hardware acceleration slider in the Work Environment?
I am not sure if it will have any affect.
Just trying to think of options.
2022-09-29 03:29 AM
As I mentioned before I set a performance threshold within the internal tool the computer has and Archicad stopped crashing but now I see a lagging on ac26 panning and orbiting in 3D
2022-09-29 03:45 AM
I have the same laptop it seems but with a little less memory than you.
I have no problem running 26, but then I am not doing any renderings with it.
Although I did do some speed tests the other day which included rendering, and although much slower than the machines I was comparing with, it did not overheat.
I don't think I have any threshold limits set.
I am not sure what temperature it is running at - not sure I even know where to look to find out.
It may well be that your laptop is just getting a little old and cantankerous now.
2022-09-29 04:01 AM
There's any free app called speedfan that's the app I'm using to monitor de temp
Honestly I don't really know I have all drives updates and everything. Very very weird
