Installation & update
Can't open a file
Created and worked with the file on Windows, then switched to Mac and it dosen't open anymore. Is this problem can be solved? Thanks in advance!
Eduardo Rolon
This is actually impossible since AC files will open regardless of platform.
Check that you copied the correct file and/or that you have the same version of AC (i.e. AC22 will not be able to open an AC23 file).
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Lingwisyer
Guru
What actually happens when you try?
