Installation & update
Cant cover the whole "building" in floor 2 by using Ctrl-A
Please help
Guessing English may be the barrier here - but I don't understand what you are unable to do?
If you are on floor 2 in 2D view, and have the arrow/selection tool active and press ctrl-A (Windows) or cmd-A (Mac) - all items on that story will be selected...
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
runxel
Hero
If you have a tool selected, Ctrl+A will only select this type.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
