Installation & update
Cant download the 28 tech preview
David Shorter
your web site thinks Im not using a desktop computer when I am. Won't let me download the 28 tech preview
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
David:
Are you using SAFARI? I could not download either but it works with CRHOME.
Hope this helps
11 REPLIES 11
David Shorter
download not working
Mac Studio
iPad Pro
iPhone
Noemi Balogh
Hi David,
If your browser / display is smaller than 7xx px (i can't recall exact number now, but basically it is below tablet size), then you'll get the message you shared. Please open the download page with a full screen display if you're accessing the site already from a desktop.
Kind regards,
Noémi
Noémi Balogh
Community Expert, Admin
David:
Hope this helps
PhilA42
Hi David:
FYI - I'm running macOS (Apple Silicon) and mine downloaded and installed just fine.  I did have to log in to my account but after that the downboad worked just fine.  My "desktop" is in fact a MacBook Pro with loads of unified memory and an Apple 27" Studio Display.
Phil
Access via Safari is less than impressive
My settings on the right and a screenshot of what started to download.
I wonder how how many Mac users had this problem.
Mac Studio
iPad Pro
iPhone
mthd
Ace
Hi David, I was able to download it from my system. Please see my specs.
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
did you use Safari?
Mac Studio
iPad Pro
iPhone
Yes.
Edit: You could try logging out with your GSID on your other devices and then log back in with your Mac Studio to see if that works ?
I used FireFox - no problem with the download.
