Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Cigraph add-ons for ArchiCAD 10
Dear Cigraph users,
I want to take advantage of this forum to explain you how the procedure for updating your Cigraph add-ons for ArchiCAD 10 works.
As I already wrote in this forum, for several reasons, the compatibility updates for ArchiCAD 10 are not free of charge: any update costs 15 Euro.
If you are a Cigraph users and you want to update your add-ons for ArchiCAD 10 you should buy these compatibility updates from www.cigraph.com
In this way you will get a new Registration ID that let you unlock the add-on for ArchiCAD 10 (that is downloadable from the same web site).
Once you unlocked this latest version, the previous one (that ones for ArchiCAD 9 or ArchiCAD 8.x) won’t work anymore: just because you changed the unlock code.
In order to use the add-ons also with the previous versions, you simply need to download and install the latest updates fro AC 8 and AC 9 (also these ones are downloadable from www.cigraph.com) . These latest updates works both with the new and the old unlock code.
If you don’t buy a compatibility update for ArchiCAD 10 you don’t need to download these latest updates: they don’t include any improvement or bug fixing: the only difference is that they handle both the new and the old unlock codes…
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
0 Replies 0
