I am having a problem opening an archicad file
When I try to open the *.pln or *.bpn file I get "Input file incorrect or memory full" How can I fix this.
This happened after I had to close Archicad and restart because the tools in archicad were nolonger working the way they should.
I'm Using Archicad 9.
TIA
Peter
7 Replies 7
You didn't mention which operating system you were using, but if it is Windows XP you should try:
1. New & Reset ArchiCAD
if that doesn't help, then
2. Reboot
3. Run my pref file cleanup ( see post here http://archicad-talk.graphisoft.com/viewtopic.php?t=10620&highlight= )
If you still have the problem post further details here.
It happened on my mac but when I try to open the files on win xp I get the same error.
I tried your file but it still does not open.
Thanks
Then you should also try this:
http://archicad-talk.graphisoft.com/viewtopic.php?t=973
If that doesn't work I would suggest sending it to tech support.
I was able to open the file like that without the error but I only get the front view of the house in 2d pasted in the o story view, so I lose all the 3d info.
thanks for your help.
Peter
Jefferson
Eric -
I was hoping you could elaborate a bit about the action your batch file does. [I've been to your webapage and my interpratation is a little foggy. Not sure if you're implying everyone should do this or just users experiencing difficulties............. ]
I will be moving in and out of 8.1 for a while, some unfinished business, and I don't want to loose my screen preferences. They're kind of a hassle to reestablish in 8.1. [No work environment like 9.........], And even though I've got copies of all my prefs stashed away, seems if the old ones are bad then the copies would be corrupt as well. So while I'd like to make certain everything is "clean" for working in 10 I don't want to screw myself in 8.1. What little chance I've had to play with 10, everything seems fine.
My thinking is always the more I know about what I'm doing I'm less likely to make extra work for myself............any advice-cation-opinions here would be greatly appreciated.
Thanks!
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
Djordje
TIA
Peter
Is your ArchiCAD set for crossplatform save? It is not by default.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Yes save in multiplatform format is on, by default I think because I did not change it.
Thanks
Peter
