Eric -
I was hoping you could elaborate a bit about the action your batch file does. [I've been to your webapage and my interpratation is a little foggy. Not sure if you're implying everyone should do this or just users experiencing difficulties.............
I will be moving in and out of 8.1 for a while, some unfinished business, and I don't want to loose my screen preferences. They're kind of a hassle to reestablish in 8.1. [No work environment like 9.........], And even though I've got copies of all my prefs stashed away, seems if the old ones are bad then the copies would be corrupt as well. So while I'd like to make certain everything is "clean" for working in 10 I don't want to screw myself in 8.1. What little chance I've had to play with 10, everything seems fine.
My thinking is always the more I know about what I'm doing I'm less likely to make extra work for myself............any advice-cation-opinions here would be greatly appreciated.
Thanks!
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
