Alzbetano
Cinerender crash on Mac
Hello!
I have been using Archicad 25 on Mac M1.
Everything used to work fine and I did render in Archicad using Cineware on that computer without any problems. however now Cinrender crashes every time I try to render. The suggested solution from previous topic doesnt work because there is no libosmesa.dylib in the computer. Do you have any idea if the problem can be solved?
Thanks!
2 Replies 2
ryejuan
have you updated your Archicad 25 to latest hotfix?
WINDOWS 11 PRO
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Alzbetano,
Thank you very much for the report and I am very sorry for the problem!
Since you mentioned that the rendering function worked fine in the past, I'm wondering if there is any change to the computer recently? Like an OS update or firewall/antivirus program installation?
When Cinerender crashes, what actually happens is that the Cineware process failed to run. If you encounter the problem again, please have a look at Activity Monitor and see if CinewareNEM process is running or not,
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
