Copy Objects
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-08-25 03:11 AM
2004-08-25
03:11 AM
What I would like to achieve, for example: "Mirror a Copy" of a window around the mid point of a wall.
Perhaps these options have been replaced with another command?
Many thanks
Lucia
ArchiCAD beginner.
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-08-25 03:16 AM
2004-08-25
03:16 AM
go to preference- miscellaneous and check the relevent box.
Alternatively (and better) hold the option key down during the non copy transformation and a copy will occur.
Cheers John
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-08-25 03:41 AM
2004-08-25
03:41 AM
Thanks Aussie John for the quick reply!
The check was missing from misc. and is now working as before.
"Option Key" is that for a MAC? I'm using a PC, is the "Control Key" the equivalent?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-08-25 04:00 AM
2004-08-25
04:00 AM
Lucia wrote:yes is for Mac- start your drag or mirror and before commiting it with enter then press your alt key( experiment) and a little plus sign if you have hit the right key
Cheers John
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-08-25 04:22 AM
2004-08-25
04:22 AM
Don't forget to mention that this is a toggle, and that you can use ctrl+alt for multiple copies! Just double click to finish the command - and no you won't copy two on top of each other doing that!
For greater speed, you don't even necessarily need to hit ctrl+D - best used with the arrow tool, just click on your selected items and start dragging them. Then have at the ctrl and alt keys all you like!
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-08-26 02:59 AM
2004-08-26
02:59 AM
Thanks for all replies and suggestions, they all worked well.
Kind regards,
Lucia
Kind regards,
Lucia
