mattmgut
Drop Down Menu UI
Please see photo attached. Occasionally when I use the drop down menu for "Documentation" and move off the menu, the menu remains. Currently I need to shut down Archicad and restart for it to go away. Are other users experiencing this? Any other suggestions to get the blank menu box to go away?
Thanks!
Matthew Guthrie
RHiZO Architecture
MacBook Pro M2 Max, 32GB
macOS 15.2 Sequoia (24C101)
AC 28
11 Replies 11
Eduardo Rolon
What I heard is that it happens when you click on a menu and AC is not active.
So in the case of Enscape if you open the Enscape window and have it in front and then click on another menu item (including Enscapes') then you get the ghost menu.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
JohnR
I have the same issue when I use AC 28 with MacOS Sequoia 15.7.3. I'd like to upgrade to MacOS Tahoe 26.2, but I don't think Graphisoft has given this OS there green light, unless I'm mistaken. If this bug is the worst of it then I'm not too concerned.
