Dual Monitors
A Question on Dual monitor setup
On A MAC i just drag the 3D window Only to the other monitor EASY.
How can i do it on WIN XP with dual monitors, JUST the ONE Window if possible. Currently i can't do it without stretching (EXTENDING) the program window over both monitors.
12 REPLIES 12
rgarand
That is the only way to do it...I think
Robert J. Garand
ArchiCAD USA 28-Build 3110 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
Thanks another good reason to persuade them to get a MAC
So this in an OS issue, not an Archicad limitation???
In a sense it is an OS issue, but the Mac does not deal with the palettes the same way that the PC does. Restore down your view and stretch the window over both monitors will achieve what you want (sort of). The down side is now you will have to set your 2D window as an individual window versus having it fill the entire area. You will also likely not be able to take advantage of the dockable palettes in the same way as you might be doing now.
if you use nvidia nview (latest driver) it will maximise the 2d and 3d window in each individual display.I am not 100% sure what your question is though.
I AM USING THE GEFORCE 6600 CARD WITH NVIDIA NVIEW (NOT SURE WHICH DRIVER YOU ARE USING AS LATEST BUT I DOWNLOADED AN UPDATE 3 DAYS AGO)
I CAN STRETCH THE ENTIRE ARCHICAD SCREEN ACROSS 2 MONITORS BUT THIS IS NOT SATISFACTORY AS THE 2D IMAGE THEN APPEARS TO SIT PART ON ONE MONITOR AND PART ON THE OTHER.
i CANNOT SIMPLY DRAG THE 3D WINDOW TO THE SECOND MONITOR. HOW ARE YOU ACHIEVING THIS.
i CAN HOWEVER DRAG 2 OR MORE SEPARATE WINDOWS FROM OTHER PROGRAMS TO THE INDIVIUAL MONITORS AS I CHOOSE.
you can set up nview in a way so that when you maximize windows in AC they will only maximize within one display. So if you dble click the topbar, the 2D window will f.ex. maximize in Disp. 1 and the 3D window will maximize in Disp. 2 .
It just takes some fiddling with the nview options, and there are many.
So:
Play with the settings in nview desktop manager and nview desktop manager wizard.
Another option is to go to www.majorgeeks.com and to download powerstrip (or any other alternative driver) and set up the dispaly options from there.
Since my last post this morning I have resolved this issue and it is working well.
I have stretched the Archicad main application window across the 2 monitors. I have then moved the 3D window onto the second monitor and kept the 2D window on the first monitor - what was confusing was the comment by the previous user that he had "maximised" the windows. This in fact, is incorrect as the windows are not maximised using the "maximise" button but rather just stretched to fill the area of the screen to a maximum. If you use the maximise button on the 2D window it then fills both screens with the plan straddling both screens which is clearly undesirable.
I am using XP pro with a Geforce 6600 card and runiing 2 HP 1230 22"monitors. takes some getting used to but it is very useful to work on 2 monitors. The screen arrangement is saved when you close the program and you only have to set this up for the first time.
The indiviual little tool bars for the 3D work are moved to the 3D screen for the first time that you use them and thereafter they appear on the 3D screen correctly each time you use them.
No, i am afraid i meant "maximized" as in pressing the maximize button. like i said, you can set nview up so that windows will only maximize in dedicated displays. You can even sub divide the screen space into as many zones as you want and have applicaitons maximize in those areas.
you can set up NVIEW in any way you want.
