Installation & update
Dual Screen Problems with Archicad
Im using a laptop and sometimes a dual screen when using Archicad, Which was running fine.. However now that I have unplugged my second screen and go to use Archicad on my laptop it has dissapeared still thinking the second screen attached.. THEN I think simply plugging the screen back will solve it.. It isn't on my second screen either, it has sent itself somewhere else? I have tried disabling multiple monitors and restarting etc still no help. Has anyone else had similiar problems when using dual screens and laptops, or does anyone know how I can solve this annoying little issue.
Archicad 12, Ati Graphics, Window XP Sp3
Thankyou
The quickest fix is to switch to a standard work environment. Once you have it sorted you should set up (and save) different work environments for your different screen setups.
Excuse my ignorance [Semi-Beginner] but could you explain a little bit more?
My initial problem has been solved, simple windows problems
