Thank you for reporting the issue and I am very sorry about the experience!
First, we need to find out what is really causing the issue. I have some theories: the Teamwork operation, the IFC files and the 3D environment:
- Teamwork operation: if you save a local copy of the whole teamwork file as a PLN, do you experience this issue on this PLN file?
- IFC files: Let's make a brand new file, hotlink the 2 IFC files and turn them into teamwork file. Can you replicate the issue here? I noticed that you said: "I could not really reproduce it in a third file", and "It just happens in this teamfile", but I'm not quite sure if you have carried out this test or not
- 3D environment: If you move the element in the floor plan (instead of moving in 3D environment), then switch to 3D, does it make the elements disappear?
Best regards,
Minh
	Minh Nguyen
Technical Support Engineer
GRAPHISOFT
