2018-12-06 01:23 PM
2018-12-06 01:56 PM
2018-12-06 02:27 PM
2018-12-06 03:16 PM
Erwin wrote:Sorting doesn't help. The Archicad algorithm is such that It still tries to load all the contents of the favorites into memory.
800 seems a bit much. That said, at that point you probably want to start sorting things in subfolders, because no-one wants to scroll through 800 items to find the one they need?
2018-12-07 02:01 AM
2018-12-07 11:19 AM
2018-12-07 12:10 PM
2019-12-11 04:46 PM
2019-12-15 09:36 PM
TISSOT_1853 wrote:You can set your favourites palette to display 2D previews rather than 3D.
When you create a Favorites dataset consisting of beams and columns using profiles, loading Favorites becomes very slow. I created 800 types of rolling stock, but it became impossible to work in the program.![]()
2020-01-06 10:12 AM
TISSOT_1853 wrote:Hi,
Noticed that the processor much load favorites based on complex profiles. For example-a round pipe with about 80 points. But another method of plotting radius curves GRAPHISOFT has not yet offered us
