Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
Feedback graphics not showing
Hi, I have a problem in AC23. When I try to edit a line into a curve there is no feedback graphics (see attachment) only the tangent, without the curve preview, and the same happens with the three points method. This happens only in one specific file, if I open a new one everything is fine. How can I fix this, without loosing the project?
Thanks!
2 Replies 2
I am not sure what would cause this in one specific file.
If it was affecting all files, I would have suggested updating video drivers, but not if it is just one file.
Can you copy & paste the lines (entire model) to a new file and keep working on it there?
May not be so helpful if you have a lot of view set up as these can't be copied from one file to another.
Thank you for the reply!
The project is relatively complex , it would be complicated to copy everything to a new file and set it up correctly, if I can't resolve the problem inside the file I will live whit this. Also I forgot to say this is a teamwork file, and the same problem is present on the other PC-s, but only in this file.
