File extensions
How do i get the file extensions .pln and .bpn to show in windows explorer. i have checked all windows based settings. Please suggest any settings thru archicad.
1 Reply 1
It's a Windows setting, not an AC one. If you're on XP with 8 and above, then in Detail or Tile view of Explorer, you'll see "Project" vs "Project Backup" with each file. But, if you want to see the extension, in Explorer go to Tools, Folder Options, View, and clear the check box for "Hide extensions for known file types".
