Installation & update
File extensions
How do i get the file extensions .pln and .bpn to show in windows explorer. i have checked all windows based settings. Please suggest any settings thru archicad.
1 REPLY 1
It's a Windows setting, not an AC one. If you're on XP with 8 and above, then in Detail or Tile view of Explorer, you'll see "Project" vs "Project Backup" with each file. But, if you want to see the extension, in Explorer go to Tools, Folder Options, View, and clear the check box for "Hide extensions for known file types".
Karl
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
