‎2023-03-04
01:45 AM
‎2023-11-15
10:46 AM
Aruzhan Ilaikova
I have both V25 & V26 installed. For no apparent reason windows (after latest windows update) has suddenly decided that all .pln files are a mystery to it and does not even recognize V26 as a possibility.
I can open files in V26 okay by using the open command in Archicad but I can't double click on the file in explorer to open it (I just get a message that this file does not have any software associated with it). Even old V25 files won't open in V25 if I double click.
Using right click, properties and searching for a program to associate with the .pln doesn't work either. I can see V25 as an option but when I search for and select V26 it just defaults straight back to V25. I had this issue when I had V24 & V25 installed as well and solved it by uninstalling V24. I'm not quite ready to uninstall V25 - is there any other potential fix for this annoying issue?
Solved! Go to Solution.
‎2023-03-08 03:38 PM
Robert, also consider that your step will restore file association to Ac26 for the PLN file format only.
You would have to do the same steps for all other Archicad-related file formats you want to be opened with AC26.
‎2023-03-08 05:42 PM
Lászó,
I think you only need to register 2-3 extensions at most. It is also a consideration that installation requires administrator rights.
In many places it is difficult and expensive to hire a system administrator to do this task which can be done independently and quickly.
‎2023-03-10 08:37 PM
That is a valid point.
