2008-07-28
12:24 AM
2024-04-29
11:59 AM
Aruzhan Ilaikova
2008-07-28 04:26 AM
techinstructor wrote:there is: model them. i use complex profile beams for this under the method described here. the wireframe/solid visibility is controlled in the layer settings: set the layers you require to be wire-framed using the shade/wireframe toggle for results much like the attached image (but in your case in reverse?).
Is there a way to show the joists in 3-DA Wireframe view?
Also there are a few places along the partition walls where I want to show gang studs for vertical structural support. What tool would be the best for doing this?do you want to show them just in 2D or in the model as well? there are framing tools that will model these for you and there are 2D objects available to draw over the top of the walls in order to recreate stud spacing for the drawings.
2008-07-28 04:38 AM
