Font will not Print
I have been trying to print a file with font Graph MM in it. Plots fine.
It will not print correctly from ArchiCAD &/or Plotmaker, the text reverts to some base font.
This only happens with ArchiCAD &/or Plotmaker an other program prints the fonts fine.
And i can print on any other machine in the office just fine, just not mine.
ACAD 8.1
Plotmaker 3.1
OS X.3
G4 Dual 1.25 ghz
3 Replies 3
The Graph MM font is a multiple master font which I believe is no longer fully supported (even by Adobe). This may be the problem. See if you can get a standard or OpenType version.
BTW. What printers are working and what is the printer that doesn't work. I don't know if it matters in this case, but you should always supply all pertinent info to make it easier to respond.
I have hear that about MM fonts but any other computer in the office can print it fine. It is only my compter that has issues. And it does not matter which printer i print to. What have and HP Laserjet 5000, HP Laserjet 5P, HP Business Inkjet 2600, Canon iR2200. The all will not print the font in the file from my computer. But any other computer in the office with print it fine.
Maybe the font is corrupted. Have you tried replacing it?
