Showing results forย
Search instead forย
Did you mean:ย
Search instead forย
Did you mean:ย
Glass problems
I'm trying to get my material "glass" to show up as both transparent (in the model) and solid (on the elevations and sections) by using "3d window Settings_Transparency in Shading: on/off." This worked in v.7 but not in 8.1. In 8.1, I cannot get the transparency to turn solid in the sections and elevations.
ajo
12 Replies 12
If you are looking for transparency in rendering only, you can set the transmittance of the glass material to 49%. It will then appear opaque in section/elevation and hidden line views.
I don't recall ever being able to get different settings in 3D and S/E. Maybe I was missing something in 7.0?
We do need the transparency to work in hidden line as well.
Then, AFAIK, you will need to change the setting in the 3D Window Settings dialog for each situation.
That is what I was able to do in v.7, but it isn't working in 8.1. Instead, we're having to use different layer combinations for clear glass and solid glass.
I just checked to make sure. It's still working as it always did for us. I ran the same elevation both ways. In one the windows were transparent and the other not, as expected.
I am at a loss as to what is causing your problem.
This is getting weirder....There's a delayed reaction to the change of Transparency in Shading in section view. After switching the transparency on or off, I have to actually select the glass in section and then look at the glass settings (ctl-T). Then, after closing the settings window, I rebuild the section. That is the only way I can get the glass to change in the sections! Then again, I may be crazy.
Tip of the month? huh huh? I want a t-shirt.
I am having no such difficulties. I change the 3D window settings and rebuild the elevation and the trasparency changes accordingly.
(Not exactly tip of the month material, sorry )
I have verified ajo's operations in the same TW project. She is on a PC, I am on a Mac G5 as the team leader. As I change transparency in the 3D window setting from off to on (as well as the other way), the glass changes transparency only after selecting the glass (walls), opening the tool settings, clicking ok w/o making any changes, then rebuilding the SE or 3D window.
I have even taken this a step further. While generating a 20,000 frame movie of this same project (saved as a .pln) in black & white, some doors with glazing would sometimes appear as solid panels instead of as french doors. Just before creating the flythru, if I select the doors with glazing, open the tool setting, click ok, the doors generate correctly. I originally thought it was a setting in the doors, but now I am perplexed. I will try this on a different 8.0 project.
mabe
G5 dual, 2GHz,1 GB ram
