Graphic error-walls not appearing correctly (wall priority?)
hi ya'll
i just upgraded to AC10 and the walls, which used to appear correctly in AC9, have missing segments or unclean intersections. I think this is purely graphical because the entire wall selects when I pick it. I've maxed out the wall priority setting, which was a temporary fix, but its still happening.
Screenshot attached. Thanks in advance.[/img]
Try the intersection priority in the layer settings. It looks like there may be some angled walls on layers turned off. Make sure layers that are off have different int priority to layers tuned on.
NICE
Problem solved. Many thanks!
-C
