‎2016-07-13 04:58 PM
‎2016-09-04 12:52 PM
Vahur wrote:"You will see almost no diference. It will be just a disappointment."
I am talking mostly about ArchiCAD slowness. Yes I compare to AutoCAD as well, but the main target is still ArchiCAD.
My point is that just an average workstation at price ~1500€ is almost equal to insane level workstation costing 5000+ €. You will see almost no diference. It will be just a disappointment. There is no difference if you must wait 10 seconds to complete the operation on ordinary workstation or you must wait 8 seconds on insane workstation. And when 2D geometry coomes into the game, seconds turn into minutes! Is it worth 3500€? You are the one who decides. As for me, I've made my choice.
Dan wrote:I am having the same question as you, Dan. And I was wondering if you are any further and can share your gained wisdome here?
Presently we are looking at Xeon E5-2640 v4 - and a motherboard that could potentially accommodate 2 physical CPU's. However at £900 per CPU we really want to be sure whether 2 physical CPU's is going to be of real world benefit.
We are trying to decipher if ArchiCAD 20 can make use of 2 physical cpu's, each with potentially 10 cores (or 20 cores including hyperthreading).
‎2016-09-05 11:24 AM
‎2016-09-05 11:47 AM
‎2016-09-07 01:53 PM
‎2016-09-07 03:48 PM
‎2016-09-07 05:41 PM
laszlonagy wrote:Hi laszlonagy,
I would recommend that you save those Morph hedges as GDL Objects. ...
‎2016-09-08 08:03 AM
‎2016-09-08 09:53 AM
sboydturner wrote:Hi,
Jeroen,
I would look at your workflow as well, if these objects just for 3D visualisations (rendering) I'd look at adding them in rendering application, or if you're using C4D or Octane you could model hedges etc as reasonably simple elements (wall/slab/morph) and use instancing to populate high poly leaves flowers etc over the hedge host element this will render much faster and with higher quality than what you can achieve in ARCHICAD.
Scott
‎2016-10-13 11:20 AM
