KDEE
Hitting Backspace button to delete text in a note crashes the program
It started in 24 but now is happening in 25 but when I use the backspace on a note to change the text the program crashes immediately. Is there a way to fix this? We can not keep working this way.
3 Replies 3
I edited your post title as it read "Hitting Delete button to backspace text ..."
It is probably a good idea to mention the operating system you are using and maybe the machine specification, so others with a similar setup can check.
I personally have not had any issues (Windows).
Have you reported this to your local support.
Take note of the bug crash number and ask them to investigate it.
If there is an issue they can't solve, then they will escalate it to Graphisoft HQ.
KDEE
Thank you for your response.
Operating system / Machine : macOS Sonoma 14.3
Processor :3.8 GHz 8-Core Intel Core i7
Graphics : AMD Radeon Pro 5500 CT 8 GB
Memory : 72 GB 2133 MHz DDR4
I have had this issue before with older operating systems. It always seems to happen after a file has been worked in for a while and only when it is a teamwork file. I have reported this to our local support but have not heard back yet.
Aaron Bourgoin
Sonoma Issue: until the bug fix is released, do not use the CAP LOCK key.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
