Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Installation & update
I Can´t login
Lorin Capelletti
Hey, so I haven´t seen this problem here before but if I try to login in myarchicad it lets me login as it should but then it loads up into the homepage wihtout me beeing logged in at all ...
there are no error codes or messages that say that any error occured so I am very confused. I am using ArchiCad for my Univerity almost 3 Years now and can not get a new licence because of this bug. Anybody had the same situation yet ?
Thanks for your help.
Operating system used: Mac Intel-based Monterey 12.6.6
6 REPLIES 6
Eduardo Rolon
Looks like you are using a VPN, try with it off.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Lorin Capelletti
Thanks for the tip but I am not using a VPN ...
Eduardo Rolon
Try using another browser or connect using the browser in your phone to see if there is an issue.
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Looks like they might be updating the EDU system and that might be the issue.
See here:
https://community.graphisoft.com/t5/Licensing/Free-trial-of-Archicad/ta-p/596179
AC27 US/INT -> AC08
another Moderator
Joe Logiudice
Graphisoft Moderator
Dear Lorin,
We recommend the following steps to resolve the issue:
1. Update your browser to the latest version.
2. Clear all-time cookies and cache in your browser.
3. Try accessing the site in private or incognito browsing mode.
4. Alternatively, you can try using a different browser.
If the above solutions don't work, we suggest uninstalling your current browser and then reinstalling it.
Giovanni Logiudice
Educational Community Expert, Moderator
Certified GRAPHISOFT ARCHICAD BIM Manager
This worked thanks !! So dont use opera to login 😄 with Safari it worked just fine.
Setup info provided by author
