2004-11-03 10:02 PM
2004-11-04 07:50 AM
2004-11-05 04:28 AM
2004-11-05 05:41 PM
2004-11-05 08:02 PM
wr1nkles wrote:The real tip is the opposite, always keep your iPod charged since it will not count towards the 400 recharging battery limit. Check ipodlounge.com for the specifics.
ahhh well, i think the tip (as with all li-ion batteries) is to run them to their lowest point, and then charge them to their fullest capacity( prefferably over night). Do this a couple of times and it should give you a bit more of a boost. The thing with ipods and apple batteries in general is that it will be inevitable that they will loose a portion of their original life. However you should get quite a bit of life out of them.
cheers, nik
2004-11-05 08:06 PM
ejrolon wrote:Does it hold true for PowerBooks also?
2004-11-05 08:21 PM
2004-11-05 10:25 PM
