We value your input!
Installation & update
Installation error: 'archicad 15.0.0 component not working'
I have recently downloaded Archicad onto my computer but when I started it up it comes with a window saying archicad 15.0.0 component not working. Any potential solution would be most helpful.
5 REPLIES 5
More info please.
Where did you download it from?
Is it a trial version, student version, full version?
What are your machine specs?
Operating sytem?
It is a student version, downloaded off the Internet. The computer handles other modelling software fine so the specs should meet the required ArchiCAD specs. I'm using Windows 7 - 32 Bit Operating System.
So it installed the program OK or is it the installer that is not working?
It installed fine however when staring the programme up it comes up with this message.
*Attached*
Thanks for your help so far.
Have a look at this web page.
http://www.archicadwiki.com/ArchiCAD15/InstallProblems
It seems like item 10 is your problem.
Give it a try and see what happens.
I was thinking maybe a quicktime problem (item 3) but you are not getting a blank splash screen.
Hopefully this will help.
